4 posts / 0 new
Last post
admin's picture
Last seen: 6 days 13 hours ago
Help Yamaha YPAO mic needed
The more i read how easy it is to set up the Yamaha RXV 2600 with the Yamaha YPAO mic the more I feel I need to get my hands on one. Does anyone have one to sell or let me use for setting up? Cant seem to find a place to purchase one.
f1only's picture
Last seen: 4 days 5 hours ago
RE: Help Yamaha YPAO mic needed
Try fleabay here Clicky
I dont know if it will do the job for you, i would ask the seller first. If you live in Ayesbury or close by you can borrow mine.
Regards ..Paul
A/V Pioneer SCLX59 Speakers B&W 683 S2 685 S2 HTM61 S2 Centre 686 S2 For Atmos x4 ASW610 Sub x2 TV Calibrated 4K Panasonic TX-50AX802B BDP Sony PS3 & PS4 Pro HDMI Monster ISF2000HD Virgin Tivo Netgear ReadyNas104 12TB
RobinKidderminster's picture
Last seen: 3 months 3 weeks ago
If not yamaha then try a local dealer
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Anonymous's picture
Will try a local dealer as a first option. Seller cant seem to find it and managed to get an extra tenner off because of it.
The ebay link is for a Denon but states it most likely works with Yamaha but rather not purchase one from US then find it just dont work. Sadly im not near Aylesbury Paul otherwise i'd grab at the opportunity to borrow for the day
Log in to post comments
