8 posts / 0 new
Last post
Glenn Larsen's picture
Last seen: 2 years 5 months ago
Help which Yamaha Surround Receiver
Hi
I am looking to buy a new surround set
I have looked at the Boston Acoustics XS 5.1 SE Speaker set
Receiver I have looked at these three:
Yamaha RX-V675
Yamaha RX-V575
Yamaha RX-V477
If I take a 7.1 system I am planning on getting two extra speakers. I am going to use it to movies mostly.
Any pro and cons?
Thanks in advance
RobinKidderminster's picture
Last seen: 1 month 2 weeks ago
Suggest u start by using
Suggest u start by using yamaha web site.to compare choosing those. specs u need
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
tried
Hi again
I have tried and I cant seem to see any remarkable differences between these. But again I am not so much into Receivers to be able to see the small differences.. Sad
bigboss's picture
Last seen: 1 week 2 days ago
I would prefer Yamaha RX-V675
I would prefer Yamaha RX-V675. It's currently discounted by 50% due to 677.
ferriolo66's picture
yamaha hmmm.
go listen to anthem and beleive me you will fall in love with the sound awesome receivers
chudleighpaul's picture
Last seen: 1 year 4 months ago
I have just bought a 675,
I have just bought a 675, very pleased with it.  Sound quality is excellent, I am using it in 5.1 mode. It has hdmi pass through in standby which is useful,  but this will not work if hdmi control is set to on. It is heavily discounted at the moment,  Richer Sounds have it for £249, so you get a good bang for your buck! The only criticism I have, applies to most receivers on the market now, is there is no switched mains out,  so I am having to make up a switching device to be operated by the 12 volt trigger supply to power up the subwoofer.
bigboss's picture
ferriolo66 wrote:
The cheapest Anthem costs 5 times the OP's budget, and the OP's speakers will not be revealing enough to benefit from the Anthem.
Thanks for all your advice
I live in Denmark so the prices are quite different.
But at the moment the 777 is on discount and only costs 75 $ more than the 677 and 100 from the 675
Thanks for all your advice!!
Log in to post comments
