Help! - HDMI for video + optical for audio - how?
4 replies [Last post]
roger06
roger06's picture
Hi - please help, I'm going mad and even Mr Google is no help.
I recently bought a Humax YouView box. The latest upgrade lets it output DD but only via Optical. I believe there was a similar issue with Sky boxes so I've only just upgraded my amp (in sig below) to the 2009 firmware to allow this.
But I can't work out the amp settings to get video thru HDMI and audio via Optical. I've connected an Optical cable and if I select this input I get the audio so that's working - so how to I then get the video via HDMI?
I hope that makes sense - please help!
__________________
Synology DS212J-> AppleTV->  rDAC->Naim Nait5i. Naim CD5i. Dynaudio Audience 52SE
Sony BDPS370 / YouView ->Yamaha RXV1065-> Pana TH42PX80B plasma.
roger06
roger06's picture
RE: Help! - HDMI for video + optical for audio - how?
Well a bit a re-Googling gave me the answer.
But now my amp display is toggling between Dolby Digital and Pro Logic. Why ? aren't they two different things?
thanks
__________________
RobinKidderminster
RobinKidderminster's picture
Online
Someone may tell you why the display toggles but for now that's what mine does and it is fine. Check the source output isok on the amp for confirmation
ie PCM displayed
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
roger06
roger06's picture
Thanks Robin
Any idea how I check what audio format is being transmitted from the YouView box?
__________________
FDixon
FDixon's picture
Smile Perhaps this information from the YouView site may help
To connect your YouView box to a surround sound system you'll need a TOSlink cable which you connect to the S/PDIF socket on the box to the Digital Optical In port on your audio system. You can get a TOSlink cable from most electrical retailers, or online. To enable surround sound on your YouView Box press the YouView button on the remote control, navigate to settings>Device Management>S/PDIF Audio Format and select Surround option. Please note: Press the (i) button on your remote control to identify which programmes are available with Surround Sound. If surround sound is available the [SS] symbol will be displayed.
