HDMI Cable question
16 replies [Last post]
mil5419
mil5419's picture
Hi all, I’m new to this forum, so be nice!
I have a simple question which I hope can get a simple answer.
I am running a Yamaha RXV371 receiver which I know isn’t the most expensive one out there, but I’m really happy with it. Connected to it I have my Sky+ HD box, my Xbox and Apple TV.
The Yamaha takes an HDMI feed from each source, then feeds the chosen signal via one HDMI cable to the TV (which is an LG 50inch Plasma  1080p).
I have an assortment of HDMI cables. One very expensive one, two middle of the road and one standard quality. My question is what is my best use of my expensive HDMI cable? Do I use it from my Sky box to my receiver, then the middle of the road from receiver to TV, or do I use the expensive one from receiver to TV, as all the sources run into that? I use the standard one from my Apple TV as its the pre 1080p version so not HD quality.
I know in an ideal world that I would have the best quality cables I can afford, but I just don’t have the budget to do that, so I need to work with what I have.
Any advice?
MIL5419
The_Lhc
The_Lhc's picture
RE: HDMI Cable question
There's no need to shout.
The only sensible answer you're likely to get is to try them in the various different places and see if you can see any difference.
__________________
No signature worth mentioning...
RobinKidderminster
RobinKidderminster's picture
Online
Gosh thats BIG text - dont need me spexs for this bad boy. Best HDMI form amp to TV IMO. Though its unlikely you will notice anything. If you want a 'good' but cheap cable I suggest 'ThatCable' £4-£6 for HDMI. Good reports and a good company to deal with without feeling you have gone over the top.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
bigboss
bigboss's picture
In my experience, I haven't noticed any difference between HDMI cables at different price points.
__________________
mil5419
mil5419's picture
Sorry all for the big text! I copied and pasted from word. Seems to have added some large shouty text!
Thanks for the replies so far
MIL5419
Son_of_SJ
Son_of_SJ's picture
As you asked so loudly, I'll see if I can answer quietly!Smile
+1. I have quite a few HDMI cables, several of them from Lindy electronics. If you search for "2m HDMI cable" on the Lindy site, you arrive at 2m HDMI Lindy cables. I happen to have several of these, in particular the 4th, 5th and 6th ones listed, costing £9:99, £9:99 and £64:99 respectively. In all honesty I don't notice any difference in picture or sound between the two cheaper ones 41112, 41162 and the very much more expensive one, 37421. Mind you, the very expensive one looks suitably intimidating, with its bright blue hard plastic braiding, so if you want to impress your friends ..... I'm using that particular cable in the kitchen, to go from the Yamaha receiver to the television.
iHarpzZ
iHarpzZ's picture
If a HDMI cable is braided and Gold Plated they are usally quite good. not that u will notice the difference but for peice of mind i would just get gold plated as they arnt that expensive.  got my branded and gold plated and braided for £8 ,brand new (ebay)
The most expensive cable would go from the Amp to the TVlisten to this
simples Smile   beauty, eh
__________________
iHarpZz =)
RobinKidderminster
Online
Hope the blue cable matches your kitchen utencils!
Sorry a bit cheeky ! Smile
__________________
John Duncan
John Duncan's picture
Formatting fixed...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
professorhat
professorhat's picture
Online
I think you're best bet is to do a very simple experiment - record a 5 minute section of TV on BBC HD (or an equivalent HD channel) - preferably something which you'd enjoy watching a lot. Now put your cheapest cable between your Sky box and your receiver, and your most expensive cable between the receiver and the TV and watch the 5 minute segment.
Now swap the cables around. If you can see a difference, decide on which you prefer and keep your setup that way. If you can't, don't worry too much about it. If you're not sure, don't worry about it too much.
Once you've done this, you know you've got the setup the best way for you and you don't have to worry about what anyone else says or thinks  beauty, eh
bigboss
bigboss's picture
In other words, you won't bother posing questions like this on a forum.  Wink
__________________
The_Lhc
The_Lhc's picture
See? Told you that would be the best answer you'd get. Probably could have told you it'd be the Professor who'd supply it but I wanted to leave some kind of surprise for you...
__________________
CnoEvil
CnoEvil's picture
Online
I have never noticed much difference between cables, but see if they have an impact on the sound....and if you feel it does, place accordingly.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
BenLaw
BenLaw's picture
Online
Surely not, Cno?  excellent!
__________________
HiFi   /   A/V   /   Bedroom
RobinKidderminster
Online
Funny how some posts just go on. And on and on.
While others.
__________________
CnoEvil
CnoEvil's picture
Online
Tongue Tongue
__________________
