Marantz introduces its £700 SR6003 AV receiver and matching Blu-ray player
Marantz SR6003
The BD7003 uses a 12-bit/297MHz DAC and can decode the HD audio formats Dolby TrueHD and DTS-HD, alongside the lossless 7.1 PCM signal converted from the original HD audio.
It will also upscale DVDs to 1080p, and the SD card slot enables easy viewing of other digital media.
However, the player is Profile 1.0 as standard, not 2.0, so it can't handle BD Live content.
Latest Videos From
The matching SR6003 receiver is clad in the company's latest 'M1' chassis, delivers 100W across seven channels and is equipped with Audyssey's Multi EQ Auto set-up and a 256-colur GUI (Graphical User Interface).
Matching AV receiver handles HD audio
The SR6003 has a 10-bit, i-Chips Technology IP00C773 video processor which upscales video via HDMI to 1080p. And on the audio side of things, the unit can process Dolby TrueHD and DTS-HS Master Audio via HDMI.
For digital music fans there's the sound-boosting M-DAX system, and the USB input recognises iTunes tag information and enables control of AAC, MP3, WAV and WMA audio files from the Marantz remote control.
Talking of which, the remote is a backlit, learning model with LCD display, the ability to learn up to 120 codes from other devices and it's macro programmable.
Multiroom fans are taken care of by the SR6003's analogue audio input for Zone A and a digital output for Zone B. You also get three HDMI inputs and one HDMI output.
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
