18 posts / 0 new
Last post
RobinKidderminster's picture
Last seen: 1 month 3 weeks ago
Dumb volume question
My amp has volume from -80db to +20db. Normal listening around -25ish. Just wondering if I am under/over driving? Is there an amp friendly volume? Dumb question? Yup maybe but wondering what levels others use.
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
BenLaw's picture
Last seen: 1 year 10 months ago
That's about right for blu
That's about right for blu rays. TV tends to be about -35. DVDs for some reason often seem quiet, maybe need it up to -15 on some.
I am the danger.
RE: Dumb volume question
In ignorance, is the 0db some kind of reference? Way to loud ofcourse. Cheers Ben.
BenLaw's picture
Exactly, 0db is the reference which I believe is 80db. Far too loud as you say.
I am the danger.
Son_of_SJ's picture
Last seen: 4 months 15 hours ago
Might the 0dB reference on volume controls be 80dBA, related to a physical measurement of air pressure? I found this link about THX reference levels http://www.acousticfrontiers.com/home-theater-blog/2013/3/14/thx-reference-level
I tend to listen to the television and the tuner (yes, I listen to the tuner section of all my receivers) at about -25dB on the receivers' volume controls. However, for listening to Blu-Rays, I tend to have the volume control (depending on in which room and therefore to which receiver I'm listening) somewhere between -21dB and -12dB.
Parlour: Sony KDL-75W855C and 12.1 system; Kitchen: Panasonic TX-P65VT65 and 8.1 system; Front bedroom: LG 60PZ950T and 5.2 system; My bedroom: Pioneer LX5090 and 7.2 system. Retired, since Sat 13-Feb-2016, Pioneer 428XD!
Thanks son-of. Interesting link. Somehow reassuring that my levels are similar to others.Cheers
BIGBERNARDBRESSLAW's picture
Last seen: 6 months 4 weeks ago
Are you lot deaf?
TV and films between -30 and -40
Very rare it goes any higher than -25 for anything.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
Pardon?
gel
gel's picture
Last seen: 6 days 22 min ago
-22 to -28 for me.
-22 to -28 for me.
Stop
BenLaw's picture
BIGBERNARDBRESSLAW wrote:
Are you lot deaf?
Like I say, TV for me is usually a max of -35, often -40 to -45. Blu ray I find tends to be quieter and / or the dialogue is a bit low in the mix so tends to be -30 to -25, often leaping for the remote for loud sound effects.
I am the danger.
Are you lot deaf?
For most tv I have the Adaptive DRC on along with the Dialogue Adjust turned to 3, so I can keep the main volume down.
I wouldn't use any of that stuff for films though, so the volume goes up a bit.
RobinKidderminster wrote:
Pardon?
There's always one isn't there.  :doh:
Yeaaaa. I seem to want to keep tweaking the volume of the centre too. Why is this? Is it my/our setup or the mix? I thought it might be because of quite a small room 13ftx11ft - is it too small to 'breath'?
BenLaw's picture
Are you lot deaf?
I listen to my TV in stereo so don't have the problem with TV. Like you I prefer to mess with film playback as little as possible.
I am the danger.
BenLaw's picture
Not sure why the size of the room would have anything to do with the relative volume of the speakers. I think it's pretty notorious that dialogue is often too low in the mix. I think the sound engineers get excited about all their explosions and want to have them as loud as possible. Problem is if you have a system capable of playing loud and dealing with extreme dynamics then bullets and explosions sound like, er, bullets and explosions. I guess it's fair enough but it doesn't sit easily with domestic life.
I am the danger.
That made.me titter. Nite nite
Pages
Log in to post comments
