18 posts / 0 new
Last post
Martin100's picture
Last seen: 1 year 16 hours ago
Denon AV3313
Please can any one advise on how to set up my Denon to listen to music through a pair of B & W CM8 and a old made up sub. I mainly listen to Spotify, all types of music, like it loud. The sound seems to be flat missing some thing, lots of top end not a lot of middle and not rich at all. When playing blue ray sounds brilliant really good. Music is poor.
I have tried it by the book. Am i missing some thing?
Denon AV3313
Denon B.Ray 3312
B & W CM8 front and center
bigboss's picture
Last seen: 5 days 19 hours ago
RE: Denon AV3313
Have you tried "Pure Direct" mode? Set your speakers to "small" (or "large" if it's already set at small) & see if it makes a difference. Have you run Audyssey setup?
Martin100's picture
RE: Denon AV3313
Have tried "Pure Direct", have tried small, large speakers, tried Audyssey set up, i think poss that is confusing the sound is the fact that i run a sub which i have to because if i play the system for long and loud periods the speakers cut out. Not sure were to put the cross over point. Speaker cables?
Poss reset the amp to factory, really loosing the will to listen......................... ROFL
RobinKidderminster's picture
Last seen: 1 month 2 weeks ago
RE: Denon AV3313
Speaker cutout sounds extreme. Something really amiss!
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
bigboss's picture
RE: Denon AV3313
Set the crossover at 80Hz first, and then adjust around it. I agree that speakers cutting out is odd. Something's amiss here. Have you checked all the connections properly?
Martin100's picture
RE: Denon AV3313
Please i am getting worried, :cry: the dealer i bought it from, which i consider reputable, set it up. Speakers cut out after about 1 month after running them in befor Christmas,  the dealer came over  saw the amount of movment of the actual speakers said he was sure that was the reason for the cut out hence the sub now working with the speakers. I belive him as he bought another amp over as well and was willing to swap it any way. I have limited the volume to 80% of max. much to the annoyance of my wife. lol
bigboss's picture
RE: Denon AV3313
Get in touch with your dealer again. Something's wrong either with the connections or the settings. Have you checked the connections?
RE: Denon AV3313
Did you not accept the new amp? No way should the speaker cones be moving 'that much'. Either the speakers or amp are faulty. As BB says - get your dealer back involved asap.
Martin100's picture
RE: Denon AV3313
The cones were flying at full blast........... So any way checked the conections all ok. Turned down the crossover on the sub to 80. It does sound better. So I must thank you guys for your help. Any other thoughts please let me know.
With Thanks
Martin
RE: Denon AV3313
Deafened only this morning at -15db. Still cant see the cones moving. They vibrate to touch but no way visible. Should I be worried I ask myself? Any higher and my intestines would wobble.
Martin100's picture
RE: Denon AV3313
Hope you are still with us and you have not blown yourself apart............So any way cranked it up a tad this morning and still no thumping drums or crashing symbols on Queens Bohemiem Rhapsody Freddies voice and piano crystal clear. Plenty of volume but i want it clear. Guitar solos are played through a blanket. Very strange. I know my hearing has changed over the years aged 54 now but surly i know when things arnt right !!!!!!!!!!
recruit's picture
Last seen: 2 years 3 weeks ago
RE: Denon AV3313
If you want good 2 channel then you might need to invest in a good 2 channel amplifier to power your speakers as trying to get great HiFi out of an AVR is not going to happen unless you are looking at the higher end models.
michael hoy's picture
Last seen: 11 months 1 week ago
RE: Denon AV3313
BB usually pure direct does not use the sub, is this what you are trying to test.
My worry is just how loud is the OP trying to go.
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
bigboss's picture
RE: Denon AV3313
Yes, it doesn't use the sub. Just want to test whether cancelling all other components improves things.
Maybe the OP should listen to music in the same room the system is set up in.  Wink
AnotherJoe's picture
Last seen: 1 year 9 months ago
RE: Denon AV3313
The OP mentions he's using an "old made up sub".
Does this sub have a direct mode or not?
If not then turn the sub volume to halfway and the crossover up to max , low filter + standby off when you do the calibration.
When playing music you want to select Pure Direct (turns the display and video circuitry off).
RE: Denon AV3313
Think OP has lost the will as he said he may. I'll move on & try to get my cones flyin'.
Pages
Log in to post comments
