Denon 2311 Help please
3 replies [Last post]
vpacalypse
vpacalypse's picture
I mistakenly ordered the wrong the wrong type of mains cable for the amplifier from ebay recently
It was a Merlin black widow mains cable, 1m.
The issue is best explained in pictures. I have the plug type below: (3 type plug)
http://img.misco.eu/resources/images/products/106/LDY/30/30138//30138_16...
However, the amp takes a 2 type plug. (scroll to page 71, see diagram of amp, plug in bottom right hand corner).
http://usa.denon.com/documentmaster/us/avr-2311ci-om-e_001.pdf
I am not entirely sure what can be done now as far as connecting it to the amp is concerned. Should I connect it anyway, Stick with original plug, or any suggestion you may have?
Andrew Everard
Andrew Everard's picture
RE: Denon 2311 Help please
Use the cable you've bought – it'll be fine.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
vpacalypse
Thank god, I was worried.
Many thanks for the quick response.
Andrew Everard
Nothing to worry about: it's just that the cable has an earth connection, and your amp won't be making use of it.
__________________
