Change my Onkyo 805 for one of these?
16 replies [Last post]
Fionn
Fionn's picture
I'm looking to change my Onkyo 805 for a 3D receiver.
I know very little about specs etc, but will be reading as much as I can.
Would any of these three be a good replacement, or would I be better keeping my Onkyo and using analogue for sound with video direct to the 3D tv.
YAMAHA RXV671 - http://www.whathifi.com/review/yamaha-rx-v671
PIONEER VSX921 - http://www.whathifi.com/review/pioneer-vsx-921
MARANTZ NR1601 - http://reviews.cnet.com/av-receivers/marantz-nr1601/4505-6466_7-34140677...
The amp will be powering Monitor Audio Apex speakers - http://www.whathifi.com/review/monitor-audio-apex/specs and the main source will be the Marantz UD7006 - http://www.whathifi.com/review/marantz-ud7006/specs.
Andrew Everard
Andrew Everard's picture
RE: Change my Onkyo 805 for one of these?
If 3D is the only reason you're thinking of an upgrade, then I'd say the most cost-effective route is the one you suggest: video straight to TV, and four pairs of analogue interconnects from player to receiver for sound.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Fionn
Fionn's picture
Thanks Andrew. 3D is the primary reason, but also I'm wondering if my Onkyo, which is around 6 years old now, is "old tech" and if the newer recievers might be an overall upgrade even though they are cheaper than I paid for the Onkyo.
markjaspi
markjaspi's picture
If your looking at the Apex & 7006BR, you will be selling them short by going with the AVRs you have listed (trust me I used own the Apex and the more power you give them, the better). Also they would seem underpowered compared to the 805, I would suggest you look at the new Onkyo replacement like for like, pioneer LX55 or Marantz SR7005 / Denon equivilant if your budget allows.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
nads
nads's picture
as a fellow 805 owner this topic has some interest.
re your last comment, there is nothing else (new) to decode all they seem to offer is more speaker options to use with the on-board software. I am more than happy with a 7.1 for when I find them and 5.1 for the rest. (dont use the processing).
My only concern is this rumour that at some time there will not be any BD players with analogue outs.... something to do with the standard that has been adpopted.
If I was going to 3D the amp would not get changed.
__________________
Not a HiFi Nut. Just has a pile of Nads.
Andrew Everard
I don't think they would: if the Onkyo's still working well, I'd stick with it
__________________
Fionn
Fionn's picture
Thanks guys.
Fionn
Fionn's picture
Another option?
What do you guys think of the Denon 2312?
I would be giving away 25w per channel (8 Ohm MA Apex) on my Onkyo if I read the specs of both correctly. Would that be a biggy?
It's a newer amp, 3D, HDMi 1.4a.
I can't find any reviews on this modle. Anybody own the 2312?
Thanks.
chris hollands
chris hollands's picture
Hi  markjaspi, just curious,  but why change your Apex for the Kef T Series ?
CH
__________________
Samsung UE46C8000 , JVC DLA-HD350 with darbee , Monitor Audio RX6av12 , Samsung BD6900 ,Yamaha RX-V3067, X-Box 360 , SKY HD 3D , Harmony One.
Fionn
Fionn's picture
Would anyone care to recommend a like-for-like replacement or thereabouts for the 805? Would the Denon 2312 I mentioned above be suitable? What about the Onkyo 609 that is so well reviewed on this site? It will be powering 8 ohm speakers. Thanks.
nads
nads's picture
if it works I would not bother.
Why do you want to change it? as that might give people an idea what to possibly sugest.
__________________
Fionn
Fionn's picture
Mainly to have 3D passthrough, using a single HDMI. Otherwise it's HDMI to the TV and a set of analogue cables to the amp. If my amp is a better decoder than the player, I will lose that.
I'm hoping somebody who knows a bit about amp specs could have a look for me and advise if the Denon 2312 would be a good replacement, or if the Onkyo wins. I've been offered a good price for the Denon, but if the Onkyo beats it, I won't be changing.
Paul.
Paul.'s picture
Denon 2312 weight: 11kg
Onkyo 805 weight: 23kg
If the Onkyo has one gift, it's brute force.  Manufacturers play fast and loose with power specifications, but the weight can be a good indicator of size of transformers etc. The Denon won't match it.
You can buy a 3d bluray with dual HDMI for under £200, much cheaper solution than replacing an amp.  This will give you all the mod cons and a hulking great amp.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
Fionn
Fionn's picture
Thanks for the replies. I've decided to go for the Onkyo 709. Already have a Marantz 7006 with a single HDMi out.
nads
nads's picture
You should have tried your 805 with the 3D. Mine works.
Edit some time later. It seems not. Or I can not get it working again......
__________________
johnjay
johnjay's picture
bdp with sub hdmi out or new avr...
BDPs with separate HDMI outputs going direct to tv for 3d picture & the other routed to an HD audio equipped AVR are emerging slowly.Take the panasonic bd310 for instance or the slightly bigger budgeted pioneer bdp lx55. If you still have a half decent AVR with HD decoding,this,at the moment is the cheapest option.But i must say i think a lot of yamahas latest aventage AVRs beginning with the A-810 up to the A-2010. These would be within a sane budget.
__________________
"Genius is born--not paid"
