B&W MT-20 5.1 best match
4 replies [Last post]
Tihi
Tihi's picture
Can anyone help me with plus and cons for AVRs to match B&W MT-20 5.1.
I cannot decide between Onkyo TX-NR609 and Marantz SR-5006.
Im currently using  B&W DM602 s3 with NAD C 355 BEE and if possible I would like to add these to have 7.1(FH) setup.
rs6mra
rs6mra's picture
RE: B&W MT-20 5.1 best match
The Denon 1912 or better still 2312 are worth considering as well as their predecessors 1910 & 2310
Tihi
Tihi's picture
Thank you for quick response, I almost ruled Denon AVR-1912 out. 2312 is out of these price range and if I would go these path the sky is the limit.
markjaspi
markjaspi's picture
I'd say go and listen to all three, the SR5006 is a fabulous AVR and much beter looking than its Denon cousins.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
Wikus
Wikus's picture
Marantz Sr5006, Denon AVR1912 and Yamaha RX-A810 does a great job, but on all of these if you can get the spec up unit (SR6006/AVR2312/RX-A1010).
M1's, while small, it does come alive with more power and you will see value in the money more spend.
__________________
Pure Home Theatre
