BOSTON ACOUSTICS SOUNDWARE XS
4 replies [Last post]
lcm1981
lcm1981's picture
Hi guys What would be the best av receiver to get with these speakers (BOSTON ACOUSTICS SOUNDWARE XS) Liam
Makaveli
Makaveli's picture
RE: BOSTON ACOUSTICS SOUNDWARE XS
The soundwares are 100 Watt speakers so your options are many. I would suggest any of the following, depends on your budget which would be suitable:
Pioneer VSX-921 (450 pounds, 4 stars from whathifi)
Sony STR-DH820 (300 pounds, 5 stars from whathifi)
Yamaha  RX-V671 (500 pounds, 5 stars from whathifi)
Denon AVR-1912 (450 pounds, 4 stars from whathifi)
Onkyo TX-NR609 (500 pounds, 5 stars from whathifi) Current favorite.
All of the above AV receivers are the new 2011 range, they are all capable of 3D as well as far as I know. Depends on what you need from your AV receiver you could go for lower ends of the ranges from Onkyo TX-N509, Denon 1612, etc.
Do audition your shortlist once you narrow your options and get the one that sounds best. In my experience most shops that stock soundware SX speakers will have them set up in their auditioning room as they are quite popular, just ask the sales guy to hook up the amp you are interested in and listen to what sounds best to you.
Have a look here as well: http://www.whathifi.com/best-buys/home-cinema-amplifiers
Hope this helps.
__________________
Samsung 3D LED 40C7000, Marantz SR5006, Boston Acoustics Soundware SX, HD PVR, PS3, MacMini, Sony BDP-S480, Logitech Harmony 1100, QED 42 strand Copper cables, Wireworld Island 6 HDMI.
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
The Pioneer is now £399.
Of the amps listed they are all contenders, the Onkyo will give you the biggest sound and keep it nice and lively.
__________________
Nick
The Home Cinema Centre
hortensio
hortensio's picture
For those Boston minis...I think you can just go for the 'mini' receivers, such as: Sony DH 810, Onkyo 309, Denon 1312, Yamaha 371...nice combos
Chris_Stork
Chris_Stork's picture
If you wanted to keep it really tidy... I would look at the new Marantz Slimline AV amps.
The NR1602 may be more money than the others there but its all packed into the slim box, with all the streaming gubbins on board including AirPlay!
Could be a contender!
