Blu Ray HD Audio Connection advice please...
9 replies [Last post]
AV-Fan
AV-Fan's picture
I need some advice as I'm currently considering an ONKYO TX-NR515 to replace my aging SONY ES 1200 Receiver because it does not do DTS HD or True HD sound.
I have B&W 684 L&R, B&W 685 SL & SR, B&W HTM 62 CS, and it seems a shame not to send some HD Audio their way banging head against wall
My dilema is that my current screens maximum video input signal is component which I use a SONY BDP S370 and use its Optical Digital Audio connection into the Receiver which doesnt send HD Audio.
Would I able to keep the component video signal to the screen (analogue) and at the same time use HDMI (Digital) Audio into the ONKYO Receiver for the soundtrack??
AV-Fan
AV-Fan's picture
RE: Blu Ray HD Audio Connection advice please...
I suppose it boils down to whether my blu ray player can output component video and HDMI audio simultaneously  doh!
Anyone know for certain if the Sony BDP S370 (the manual isn't particularly clear on this) is capable of this.
Many thanks for help with this.
Is the ONKYO TX-NR515 suitable with B&W 600 series speakers or should I be aiming to the next price category up from this (£1000).
I appreciate any advice on the amp as I cannot audition before I buy as I am housebound.
Thanks again.
bigboss
bigboss's picture
Online
Can't help thinking you've got a hugely mismatched system. You will definitely benefit with a receiver upgrade. Which TV have you got?
__________________
AV-Fan
AV-Fan's picture
Currently using pre outs for front L&R into stereo amp for music.
Any new receiver would preferably have pre outs connections.
AV-Fan
AV-Fan's picture
Fully aware of the weak links in my system, yes.
But for now, before clicking buy now, can blu ray output component video to the TV as well as sendinf HD Audio into the ONKYO receiver.
Thanks.
AnotherJoe
AnotherJoe's picture
Can you not tell the ES to take the video from component, and the audio from hdmi ?
If you set the S370 to output PCM then you will have your lossless sound.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
bigboss
bigboss's picture
Online
The one option I can think of is to buy a blu ray player with twin HDMI outs, like Sony S790 or Panasonic BDT 500 or Pioneer LX55. Use an HDMI to SCART converter to connect HDMI 1 to your TV & connect HDMI 2 to your AV receiver. This should work.
__________________
bigboss
bigboss's picture
Online
Thanks.
I meant you should go higher up than the Onkyo you're considering.
__________________
AV-Fan
AV-Fan's picture
Thank you AnotherJoe for this suggestion. I am off to try it now.
AV-Fan
AV-Fan's picture
Thank you Big Boss,  like the current What Hi Fi best buy Pioneer VSX-LX55 ?
Albeit a big leap of faith as I cannot audition in person and would have to order online.
I am open to recommendations to partner B&W 600 series.
Thanks.
