3 posts / 0 new
Last post
admin's picture
Last seen: 1 day 17 hours ago
Bi-wiring '81 amps.
Hi
I want to bi-wire my Pioneer 81 amp - it runs in 5.1, yet the manual says use the rear surround channels for bi-wiring??
Can I use the side surround channels and get the same effect?
Any help greatly received.
Thanks,
Jason.
The_Lhc's picture
Last seen: 3 months 6 days ago
RE: Bi-wiring '81 amps.
I imagine it probably says use the rear-surround channels for bi-AMPing.
Probably not, if you're running 5.1 then you should be using the side surround channels for, well, the side surround speakers, rear surrounds are only used in a 7.1 configuration, that's why they can also be used to bi-amp the fronts if you wish to do that (and providing the amp allows for it).
Anonymous's picture
Thanks - i've re-read it and it actually says use the back surrounds for bi-amping - makes sense!
Log in to post comments
