Bi Amping a Pioneer SC-LX85
6 replies [Last post]
willcoxi
willcoxi's picture
Anyone out there a Bi amp’ing expert, especially with a Pioneer SC-LX85. I am already using all 9.2 channels on the Pioneer and am looking to bi-amp the front soundstage (Monitor Audio GX300/350). How do I use the pre outs on the Pioneer to best effect this? Can I use a few power amps to drive each speakers HF input and use the Pioneer to drive the LF inputs or is there a better way???. Or am I totally off the wall !
willcoxi
willcoxi's picture
RE: Bi Amping a Pioneer SC-LX85
PLease help !!!, this is driving me internet crazy !!! cheer
KiwiMoto
KiwiMoto's picture
I'm thinking the same thing.Rotel RB 1572 (250w class D per channel)is looking good...
__________________
Panasonic PT AE8000*Yamaha Aventage A3020*Pioneer BDP 450*Project RPM 9.1*Dynavector P75*Klipsch RF/RC/RS 62 II*Klipsch RS41 II front height/rear surrounds*Velodyne SPL1000Ultra*Da lite 110" 2:35:1*DVDO Duo i/p scaler*Apple TV 1080p*MySky HDi*Cables-Wireworld Chroma 6 HDMI/QED Silver Anniversary XT/Chord Crimson plus/Clearer Audio Copper line mains*Control4 automation*
willcoxi
willcoxi's picture
It's the 'how' am fretting about ?. Any ideas in a 9.2 setup ?
The_Lhc
The_Lhc's picture
Exactly as you said, you need an additional channel of amplification for each speaker you wish to bi-amp. Personally, although  it depends on the quality of the power amps you get, I'd be inclined to stick the LF through the power amp and keep the HF on the LX85.
__________________
No signature worth mentioning...
willcoxi
willcoxi's picture
Much appreciated ta  Smile
willcoxi
willcoxi's picture
Spoke to both Pioneer and Monitor Audio. Cut a long story short, anything is possible but key recommendation from MA is to keep the speakers powered by the same amp, ie power amp or receiver, to keep the balance in the system. Seems like sensible advice. The MA guy also suggested using RCA splitters on the ore outs which solves another problem of how to split the signal to a power amp without a pre in/ out. All sensible stuff !
