6 posts / 0 new
Last post
bonzo75's picture
Last seen: 3 years 2 months ago
AVR 360
HI I have just bought an AVR 360. As long as I use it on a B&W CM 8 or KEF R500s, I am happy with the output. I have never tried it on a really big B&W type speaker, so do I have anything to fear in case I go in for B&W 804s, or KEF reference series (I will buy them used). The speakers will be used in a 5.1 set u - with a PV1D subwoofer, CM1s, and a CM centre.
My room size is an average London room, think 16ft * 18ft.
CnoEvil's picture
Last seen: 5 days 11 hours ago
RE: AVR 360
My answer is the same as in your last thread, regarding the AVR360 and Kef Refs.......it takes at least an AVR600 to drive them to a reasonable degree.
I have a little experience in this, as I have owned an AVR350, do own 205/2s and AVR600.
You should try and stick with one speaker brand for the front 3 speakers, preferably the same model.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
bonzo75's picture
RE: AVR 360
Thanks Cnoevil. Would that rule out AVR 500 as well, am asking since that can be available cheaper
CnoEvil's picture
RE: AVR 360
The AVR500 would be much better, though not quite there (imo)..........but it's so "buggy" that I wouldn't touch it.
bonzo75's picture
RE: AVR 360
Hi Cnoevil, any thoughts on what is better - an AVR 360 teamed up with a power amp to drive the front two, while the 360 drives the sub and the rears or just an AVR 600 that drives all 5.1s alone? Which provides better sound for music?
CnoEvil's picture
RE: AVR 360
IMO. The AVR600 is a remarkable stand alone piece of kit, has enough current to drive difficult speakers, and sounds like a very decent 2 channel amp when playing music (using Stereo Direct). So to keep things simple, I would go this route.
The only question mark is over whether all the bugs have been ironed out in it, so make sure the 5 year warranty has been activated and goes with the machine.
Nb. The above advise is simply my personal opinion having heard a few AV amps and a lot of stereo ones.
Log in to post comments
