AV Upgrade time help required
4 replies [Last post]
Leehallam
Leehallam's picture
It has come time to upgrade my Denon 1910 that has been a great peice of starter kit. I have it conected to a B&W 685 theatre speaker set up.
I am looking to expand my system well as future proof it so I am looking for something with pre-out and phono input.
I am torn between 2 amps the Onkyo TX-NR809 or buying a Pioneer VSX-LX53 for around the same price now. I listen to my system 50% movies and 50% music so needing a good balance of the 2.
Any help would be greatly appreciated
__________________
Roksan Caspian M2 Amp & CDP - B&W PM1's - QED Revalation - Roksan Radius 5.2 - Ortofon Black MM - Audiolab MDAC - Denon AVR3312 - Apple TV - Sonos ZP90 - B&W 685 theatre - Panasonic tx50gt30b - Pioneer bdp320 - Sonos 2 x zp 120 - B&W 686 2 x Sonos s5's
In the bar:- Roksan Kandy K2 - Rega Dac - B&W 685
Cofnchtr
Cofnchtr's picture
RE: AV Upgrade time help required
The Pioneer 53 doesn't have a dedicated phono input.
Cheers,
Cofnchtr.
__________________
Panasonic TX-50GT30B | Pioneer VSX-LX53 | Pioneer BDP-LX54 | B&W M1 x 5 | REL Strata | SKY+HD 1TB | Harmony One Remote | Contentment.
Leehallam
Leehallam's picture
Cofnchtr,
Thanks for that my dealer got it very wrong and I did not look need to pay more attention next time.
Back to the drawing board.
What should I buy with phono input and pre out?
Or should I go with a av amp with preout and buy a stereo amp as well.
Can any one help with some advice.
What would be the best stereo amp to pair up with some B&W 685.
Thanks Lee
__________________
Trousertrumpet
Trousertrumpet's picture
To be honest, I swapped out an Arcam amp for a Yamaha RXV667 AV amp to go 5.1 and didn't notice any change in quality from the music perspective, so much so I didn't bother with the faff of pre-outs to the Arcam. Seems to me, that modern AV amps are very accomplished in stereo too.  After all, modern film soundtracks are higher resolution and more demanding than the average CD! Smile
__________________
All that glitters is not gold.
Cofnchtr
Cofnchtr's picture
You could get a phono amp and use a line in on the Pioneer if you like the sound of the Pioneer?
Prices may fall a bit when Pioneer introduces the latest amps?
Cheers,
Cofnchtr.
__________________
