Av receiver for B&W dm600 S3 5.1 setup
20 replies [Last post]
MrKay00
MrKay00's picture
i have the old b&w speakers the dm600 series 3. my setup is dm600 s3 for rear and dm602 s3 for front speaker and lcr60 s3 for center and i am looking for a new av receiver my budget is £500 and i will be using this for 2d,3d blu ray movies thanks
MrKay00
MrKay00's picture
RE: Av receiver for B&W dm600 S3 5.1 setup
i accidentally made two post can some one please delete the other same post thanks
MUSICRAFT
MUSICRAFT's picture
MrKay00 wrote:
Hi MrKay00
I know the 600 Series speakers as i used to sell these.
At a budget of £500 Yamaha's RX-V671 will do the trick nicely Smile
Btw, have you already got a receiver and sub? If so what make and models are they?
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
MrKay00
MrKay00's picture
thanks for your reply. I have a very old av receiver its a kenwood model krf v5050d i have no sub at the moment but will be buying one of the same model if i can find one. does the Yamaha's RX-V671 have 1.4 hdmi as well thanks
MUSICRAFT
MUSICRAFT's picture
MrKay00 wrote:
Hi MrKay00
Thanks for your reply and your welcome.
You'll find the RX-V671 to be a worthwhile upgrade and its overall tonal presentation suits 600 Series speakers just nicely Smile Yes the RX-V671 has 1.4 specification HDMI's.
Btw, the ASW675 sub woofer will be the icing on the cake. There is an ASW675 on Ebay.UK at the moment.
All the best
Rick @ Musicraft
__________________
MrKay00
MrKay00's picture
Thank you again for your reply
MrKay00
MrKay00's picture
Hi MUSICRAFT,
do you think i should sell my current setup and get the B&W MT-30 would they be better then the setup i have now thanks
MUSICRAFT
MUSICRAFT's picture
Hi MrKay00
Your welcome.
All the best
Rick @ Musicraft
__________________
MUSICRAFT
MUSICRAFT's picture
MrKay00 wrote:
Hi MUSICRAFT,
Hi MrKay00
No. I'll recommend that you carry on using your speakers for a while yet as these 600 series speakers are some of the finest which B&W have produced and are also capable of higher levels of performance then the MT-30. Adding a ASW675 will be the icing on the cake Smile
Btw, is £500 your limit for an AV amp? The reason i ask is because as good the RX-V671and other amps are at this level however your speakers can benefit further from even higher calibre of amplification. Something worth bearing in mind.
All the best
Rick @ Musicraft
__________________
MrKay00
MrKay00's picture
thanks for your reply again. I wanted to stay in the £500 mark but can go over. how much is it and what make and model are they thanks
hortensio
hortensio's picture
I would suggest you to try Denon avr 2311 (or even 2310 if you don't need 3D)...it mathes very well with B&W...
MrKay00
MrKay00's picture
Hi hortensio,
Thanks for your reply. But i need the 3d. am using a hd 720p projector that has 3d but will be upgrading to a 1080p 3d projector soon. is the Denon avr 2311 better then the Yamaha's RX-V671 thanks
MrKay00
MrKay00's picture
can some one also please help me with what cables i should get for my speakers at the moment am using them cheap richer sounds cambridge audio symphony 100 or 200 ones not sure which one it was thanks
MUSICRAFT
MUSICRAFT's picture
MrKay00 wrote:
Hi mrkay00
Your welcome.
Staying close to the £500 mark Yamaha's new Aventage RX-A810 (RRP £850) is worth a look. As good as the RX-V671 is however the RX-A810's overall quality of power and performance are much better which your 600 series will easily benefit from Smile Alternatively the recently discontinued RX-V1067, RX-V2067 and RX-V3067 are also worth considering as you may still find these amps at very good prices.
All the best
Rick @ Musicraft
__________________
MUSICRAFT
MUSICRAFT's picture
MrKay00 wrote:
Hi MrKay00
I'll recommend that you should carry on using your existing speaker cables.
All the best
Rick @ Musicraft
__________________
MrKay00
MrKay00's picture
Hi MUSICRAFT,
Thank you very much for your replys again. i will be getting the Yamaha receiver gonna look in to the models u have given me thanks again
