Adding a power amp???
3 replies [Last post]
atkins4725
atkins4725's picture
Evening gents/ladies, looking for some info regarding power amps. I'm thinking about adding the marantz mm7025 power amp to my SR7005 to help drive my 683's.
How does it work exactly? Is power delivered from both amps or just the power amp?? If so, are we taking noticeable differences in control of my speakers taking into account the power amp cost around £650 and delivers only an extra 15watts per channel ??
__________________
Philips 56PFL9954H, Sky HD, Marantz SR 7005, CA 751bd, Monitor audio Apex, Chord Prodac, Chord active HDMI's, Chord chorus 2, Chord odyssey 2, Atacama equinox rack.
ISAC69
ISAC69's picture
RE: Adding a power amp???
Hi ,
It is very simple you connect the front speakers to the power amp . than you connect  the MARNANTZ SR 7005 with RCA cabels via the front RCA (red/white) pre out  to the power amp . only the power amp will give the power to the front speakers
and your AV receiver wil operate as pre out only for them . You should consider a significant differences in control of your speakers in terms of
power but much less in terms of sound quality .
__________________
Hi Fi : ROKSAN KANDY K2 - PROAC STUDIO 140 MK2  - ROTEL RCD1520 -  interconnects : Tellurium Q Black - Chord Chorus2
AV : YAMAHA RXV767 - INFINITY PRIMUS PS8 [SUB]
atkins4725
A total waste of money then!!
__________________
KiwiMoto
KiwiMoto's picture
I went down this track and the MM7025 made a big difference to my SR7005.Those B and W's need a lot of power to do them justice,and adding this amp will do it.IMO,a no brainer. But then i tired of the Marantz and bought a Pio LX85 and whamo...no outboard amp required Smile
__________________
Panasonic PT AE8000*Yamaha Aventage A3020*Pioneer BDP 450*Project RPM 9.1*Dynavector P75*Klipsch RF/RC/RS 62 II*Klipsch RS41 II front height/rear surrounds*Velodyne SPL1000Ultra*Da lite 110" 2:35:1*DVDO Duo i/p scaler*Apple TV 1080p*MySky HDi*Cables-Wireworld Chroma 6 HDMI/QED Silver Anniversary XT/Chord Crimson plus/Clearer Audio Copper line mains*Control4 automation*
