22 posts / 0 new
Last post
Teeza's picture
Last seen: 1 year 11 months ago
Two amps - one set of speakers
Teeza's picture
RE: Two amps - one set of speakers
[Third time lucky? - why does this site keep losing the body text?]
I have an AV amp and 5.1 speaker set-up used for all sources but I don’t like the sound with music.
I have another amp that I prefer for music listening but I only have room for one set of speakers.
What is the best way to enable both amps to output to the single set of speakers (not simultaneously)?
All suggestions gratefully received.
Ryan92's picture
Last seen: 3 years 3 months ago
If your receiver has pre outs . . Then
http://www.whathifi.com/video/how-to-add-hi-fi-to-your-home-cinema
On the very site Smile
Teeza's picture
Thanks Ryan. [Couldn't see anything using IE - switched to Firefox and all OK.]
That's something I could try BUT is it the only option?
Presumably that could "unbalance" the sound with movies as the main fronts will be driven by the music amp.
Could the spare (bi-amping) terminals on the speakers be utilised (without removing the jumpers)?
Is there a such a thing as a speaker switch box or splitter?
Andrew Everard's picture
Last seen: 3 years 5 months ago
Not really: either the AV receiver's automatic set-up will take care of this, or you can adjust levels manually in the receiver's set-up menus. And some stereo amps are desined with a 'unity gain' or 'AV bypass' input for just this purpose.
No – that'll connect the receiver and the amp together, and runs a serious risk of blowing the output section on one or both of them.
There's one made by US company Niles, but it seems hard to come by, and Beresford makes one, but I haven't tried it.
MajorFubar's picture
Last seen: 5 hours 7 min ago
Not too difficult to throw together a basic two-way speaker switcher which only connects one amp at a time to your speakers,  You can even cobble one together from a two-gang two-way light switch from B&Q/ebay etc.  You only need to switch the +ves, the returns can stay connected.  Or if you feel you really must disconnect the -ves too, buy a four-gang two-way switch.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
Teeza's picture
Perhaps "unbalanced" was a poor choice of adjectives - I was thinking more in terms of tonal quality. Something to trial I think.
Good point Andrew - well received.
The Niles product wouldn't win any beauty contests! The Beresford has a couple of good reviews linked to the site, it seems well priced and is (a little) prettier. Worth considering.
Does anyone have one of these units?
Teeza's picture
RE:Two amps-one set of speakers
Teeza's picture
You are probably right but as I don't even seem able to post text to this forum without either losing or duplicating it - I'll leave that to people with more fingers than thumbs!
Teeza's picture
You are probably right but as I don't even seem able to post text to this forum without either losing it, duplicating it or failing to quote !- I'll leave that to people with more fingers than thumbs!
RE: RE:Two amps-one set of speakers
Indeed, but provided you're using a receiver with automatic set-up and equalisation, that should take account of any difference in tonality between the amp and the receiver, and adjust the receiver's front-channel EQ accordingly
The_Lhc's picture
Last seen: 3 months 1 week ago
There are a number of people running this kind of setup on here, none of them have an issues around tonal matching.
Including me: Onkyo TX-SR875 (at the moment) into the Naim SuperNait's unity gain AV input, and it works splendidly for movies, while taking the elderly Onkyo out of the equation when streaming music.
Teeza's picture
Indeed, but provided you're using a receiver with automatic set-up and equalisation, that should take account of any difference in tonality between the amp and the receiver, and adjust the receiver's front-channel EQ accordingly.
It’s not that I don’t believe you (I do!) but I find this somewhat counter-intuitive. Amps can have such different and distinct voices that I find it hard to accept that auto-equalisation can turn a humble device into an electronic mynah bird. Is mimicry just careful equalisation?
The equalisation will endeavour to achieve a flat frequency response, so if the stereo amp in use has a distinctive character, the EQ will adjust the frequency response of the affected channels to flatten things out again as well as it can.
It does this just as it will boost the gain of the front channel outputs should the stereo amp not deliver as much gain as the amps inside the receiver used for all the other channels, and compensate should the amp introduce some delay into the chain (which the receiver will 'see' as the front speakers being further away, invert phase, and so on.
Of course this will only affect the operation of the system when in home cinema mode, and will have no effect on how the stereo amp sounds when playing music.
And before anyone else asks – what's your receiver, stereo amp and speakers?
margetti's picture
Last seen: 1 year 7 months ago
Hi Teeza, I have one and have been very pleased with it from day one. I personally felt it made a noticeable difference with the front stage, but then again I never made any effort to do any kind of ABX testing etc. In hindsight I do also wonder if I'd put enough effort into the Audessey set up previously, which benefited greatly from spending time gettin right.
What did make me uncomfortable using the AVR/stereo combo was the amount of time it meant my stereo amp was on, which is Class AB and produces more heat than the Onkyo! As my stereo amp has no remote, other members of the family would invariably leave it on overnight which would get my goat up also!
Pages
Log in to post comments
