Two amps - one set of speakers
19 replies [Last post]
Teeza
Teeza's picture
Teeza
Teeza's picture
RE: Two amps - one set of speakers
[Third time lucky? - why does this site keep losing the body text?]
I have an AV amp and 5.1 speaker set-up used for all sources but I don’t like the sound with music.
I have another amp that I prefer for music listening but I only have room for one set of speakers.
What is the best way to enable both amps to output to the single set of speakers (not simultaneously)?
All suggestions gratefully received.
Ryan92
Ryan92's picture
If your receiver has pre outs . . Then
http://www.whathifi.com/video/how-to-add-hi-fi-to-your-home-cinema
On the very site Smile
__________________
Currently works at Currys.
Macbook/iPhone - ATV2 - AVI ADM9T + Sub
PS3, 42GT30, Tivo, BD110
Teeza
Teeza's picture
Thanks Ryan. [Couldn't see anything using IE - switched to Firefox and all OK.]
That's something I could try BUT is it the only option?
Presumably that could "unbalance" the sound with movies as the main fronts will be driven by the music amp.
Could the spare (bi-amping) terminals on the speakers be utilised (without removing the jumpers)?
Is there a such a thing as a speaker switch box or splitter?
Andrew Everard
Andrew Everard's picture
Not really: either the AV receiver's automatic set-up will take care of this, or you can adjust levels manually in the receiver's set-up menus. And some stereo amps are desined with a 'unity gain' or 'AV bypass' input for just this purpose.
No – that'll connect the receiver and the amp together, and runs a serious risk of blowing the output section on one or both of them.
There's one made by US company Niles, but it seems hard to come by, and Beresford makes one, but I haven't tried it.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
MajorFubar
MajorFubar's picture
Not too difficult to throw together a basic two-way speaker switcher which only connects one amp at a time to your speakers,  You can even cobble one together from a two-gang two-way light switch from B&Q/ebay etc.  You only need to switch the +ves, the returns can stay connected.  Or if you feel you really must disconnect the -ves too, buy a four-gang two-way switch.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Cyrus 2 + PSX  > Cyrus tuner > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Technics SL-P777; Marantz CD63 mkII KI; Marantz PM66 KI; Nakamichi DR-1
Teeza
Teeza's picture
RE:Two amps-one set of speakers
Perhaps "unbalanced" was a poor choice of adjectives - I was thinking more in terms of tonal quality. Something to trial I think.
Good point Andrew - well received.
The Niles product wouldn't win any beauty contests! The Beresford has a couple of good reviews linked to the site, it seems well priced and is (a little) prettier. Worth considering.
Does anyone have one of these units?
Teeza
Teeza's picture
You are probably right but as I don't even seem able to post text to this forum without either losing it, duplicating it or failing to quote !- I'll leave that to people with more fingers than thumbs!
Andrew Everard
RE: RE:Two amps-one set of speakers
Indeed, but provided you're using a receiver with automatic set-up and equalisation, that should take account of any difference in tonality between the amp and the receiver, and adjust the receiver's front-channel EQ accordingly
__________________
The_Lhc
The_Lhc's picture
There are a number of people running this kind of setup on here, none of them have an issues around tonal matching.
__________________
No signature worth mentioning...
Andrew Everard
Including me: Onkyo TX-SR875 (at the moment) into the Naim SuperNait's unity gain AV input, and it works splendidly for movies, while taking the elderly Onkyo out of the equation when streaming music.
__________________
Teeza
Teeza's picture
Indeed, but provided you're using a receiver with automatic set-up and equalisation, that should take account of any difference in tonality between the amp and the receiver, and adjust the receiver's front-channel EQ accordingly.
It’s not that I don’t believe you (I do!) but I find this somewhat counter-intuitive. Amps can have such different and distinct voices that I find it hard to accept that auto-equalisation can turn a humble device into an electronic mynah bird. Is mimicry just careful equalisation?
Andrew Everard
The equalisation will endeavour to achieve a flat frequency response, so if the stereo amp in use has a distinctive character, the EQ will adjust the frequency response of the affected channels to flatten things out again as well as it can.
It does this just as it will boost the gain of the front channel outputs should the stereo amp not deliver as much gain as the amps inside the receiver used for all the other channels, and compensate should the amp introduce some delay into the chain (which the receiver will 'see' as the front speakers being further away, invert phase, and so on.
Of course this will only affect the operation of the system when in home cinema mode, and will have no effect on how the stereo amp sounds when playing music.
And before anyone else asks – what's your receiver, stereo amp and speakers?
__________________
margetti
margetti's picture
Hi Teeza, I have one and have been very pleased with it from day one. I personally felt it made a noticeable difference with the front stage, but then again I never made any effort to do any kind of ABX testing etc. In hindsight I do also wonder if I'd put enough effort into the Audessey set up previously, which benefited greatly from spending time gettin right.
What did make me uncomfortable using the AVR/stereo combo was the amount of time it meant my stereo amp was on, which is Class AB and produces more heat than the Onkyo! As my stereo amp has no remote, other members of the family would invariably leave it on overnight which would get my goat up also!
__________________
Sonneteer amp, cdp & phono amp, Systemdek IIx900, Onkyo 876, Ruark spkrs + REL sub, bits and bobs
Teeza
Teeza's picture
Thanks Margetti. Can you confirm one thing it said in the review that is absent from the manufacturers site:
Although only one amp can be switched through at any one time (this is OK) the reviewer said that amp could then feed both sets of conected speakers - is that right? Can buttons A & B be in the "on" position at the same time?
I think we all have issues with training our families how to operate our kit. Roll on the invention of the remote that can read minds!
Teeza
Teeza's picture
I've just re-watched the video and it does suggest there could be issues with tonal matching. Glad it does not affect your set-up. I think I just need to try it out. The next problem is access to the back of my kit - don't know any anorexic contortionists by any chance?
