iPhone as a Sonos / Spotify Controller
12 replies [Last post]
Jason36
Jason36's picture
Hi guys I have asked this question in the Hifi section with no replies, so thought I would try here as well.
Having recently sold my CD player, to be replaced with a Sonos Bridge and ZP90 to stream music to my hifi (a NAS will be added at a later date) I was wondering if anyone uses their iPhone as a controller for either Spotify or Sonos to stream music to their system.
How does the screen on the iPhone handle the controllers...are they easy to read, navigate, understand etc. I have the option of using my iPhone 4 to do this or wondering if I should opt for an iPad (although it will only really be used as a controller) and dont really want to spend the money unless I really have to.
__________________
Main System: Laptop > Schiit Modi DAC & Schiit Magni HP Amp > Headphones
Portable: Rockboxed & Modded iPod (128Gb CF Card) / iPad4 / iPhone 4S / ALO National Amp / ALO Rx Mk3-B Amp / AlgoRhythm Solo DAC
Headphones: Sennheiser HD650 / Beyerdynamic T70p / Heir Audio A.4i IEM / Aurisonics ASG 1.2 / Sennheiser IE6 IEM
Lee H
Lee H's picture
RE: iPhone as a Sonos / Spotify Controller
Works fine for me. I actually have the iPhone, iPad and CR200!
iPad is visually very impressive, but the iPhone copes just as well. The screen is the same size as the CR200 so there is little difference.
__________________
Formerly Still known as Lee H
cram
cram's picture
Yeah Iphone works fine. Slightly laggy in terms of response compared to the CR200 but this isn't really a bit issue. Just be aware that you need to make sure that you need wi-fi in whatever area you want to control your sonos. I've similar to Lee H in that I have Iphone, Ipad, CR200 along with the CR100. Being honest the CR200 is my favourite controller but an Iphone (or Ipod Touch) is more than acceptable.
eggontoast
eggontoast's picture
I use the iPhone app and also have a CR200.
The iPhone works perfectly well and the screens are well laid out. Personally I do prefer using the CR200 to the iPhone it is just a slightly better experience, whether that slightly better experience is worth the £224 outlay for a CR200....probably not.
__________________
Sonos > M-DAC, Beyerdynamic A1, FiiO E17/E9, HLLY DMK-IV, STAX Lambdas, Denon AH-D5000, Sennheiser HD-600, Beyerdynamic DT770, MCA customs - Magnum V4's, Sennheiser HD-265 linear, Sennheiser CX300-II.
Jason36
Jason36's picture
Cheers guys......
Just found out I cant upgrade my phone to the iPhone till December (although good news is the iPhone5 should be out then). I looked at the CR200 controller but in honesty I can get a 32gb WiFi and 3G iPad for £44.00 on my current business contract.
I also have a Samsung Galaxy at the moment, which I use Spotify Premium on and I know they do a Sonos Application which is probably just the same as / good as the iPhone one.....so could also use that until upgrade time.
Sounds like all options....Samsung Galaxy S, iPhone or iPad will be adequate and perfect for the requirement.
Once again Cheers.
__________________
eggontoast
Probably should have also added that the misses has a Galaxy Ace with the android Sonos app on and IMO it is nowhere near as good as the iPhone one. To me like most of the android based software it just looks homebrew.
__________________
The_Lhc
The_Lhc's picture
What are you talking about? It looks exactly the same!
It IS missing a few features at the moment but that was no different to the iPhone app which took a few iteration before everything was added to it.
__________________
No signature worth mentioning...
eggontoast
No it doesn't
__________________
The_Lhc
The_Lhc's picture
eggontoast wrote:
No it doesn't
http://www.sonos.com/system/
Look at the image of all the controllers together, the one at the front is the CR200, behind that is the Android app, behind that the iPhone, they're near as dammit identical.
Are you sure she's not using Andronos?
__________________
eggontoast
Listen The_Lhc, I'm not really interested in your waffle but I should expand as reading between the lines appears to allude you, look feel and usability of the apps.
I have used all three and IMO they are ranked in order 1) CR200 2) Iphone app (just behind) and 3) Android app (some margin behind the above two) of course others may have a different experience.
__________________
Lee H
Lee H's picture
On phone/pad based apps you get to use the superior keyboard to the CR200, but lose a smidgeon of response time (and it uses your own wi-fi rather than the mesh net). With the CR200, response is quicker, keyboard is woeful and it uses the mesh network.
__________________
The_Lhc
The_Lhc's picture
That doesn't make sense.
And that's fine, I've used all three as well and wouldn't argue too much with your expanded explanation (although the hardware volumes buttons on the Android app are better than the iPhone's option) but saying the Android controller looks "homebrew" is still nonsense.
__________________
eggontoast
When is your next Apollo gig ?
shhh
__________________
