Spotify remote wont load on ipad..
Sat, Jan 7 2012, 5:24PM
Subscibed to spotify remote and when it comes up- Select computer, it says that there are 0 servers available?? I have spotify on my macbook and am using my timecapsule for the wifi.. There is a picture of the time capsule when i press help. Is this causing the conflict??
Help plse
John
Wed, Jan 11 2012, 9:17AM
#2
The spotify remote apps need a server program to be installed on your MacBook as well. If you visit the app developers website it should be fairly easy to find. If you've already got it installed then I'm not sure why it's not working. Could always try the turn it of and on again method, and uninstalling and reinstalling the app.
Will try that JonnyD thanks for the reply
- Login to post comments
MacBook - Beresford Bushmaster - Rotel RA-05 - B&W 685's
