20 posts / 0 new
Last post
gel
gel's picture
Last seen: 21 hours 26 min ago
iPad Problems
Hi
My iPad won't let me access my emails on Btinternet, has anybody else got this problem?  What should I do?  Thanks
Stop
bigboss's picture
Last seen: 1 week 4 days ago
Reboot the iPad.
Reboot the iPad.
gel
gel's picture
RE: Reboot the iPad.
bigboss wrote:
Reboot the iPad.
Thanks, I will do it now.   :cheers:
Stop
bigboss's picture
If that doesn't work, check
If that doesn't work, check email settings, re-enter your password, & check server settings.
gel
gel's picture
RE: If that doesn't work, check
Done, still not working.  Any ideas?  Tried it on my laptop and is working.  Tried it on a different iPad and still not working!
Stop
gel
gel's picture
I can't get the correct time
I can't get the correct time at the top either now!
Stop
gel
gel's picture
I am still not getting any
I am still not getting anywhere! :wall:
Stop
The_Lhc's picture
Last seen: 4 months 1 week ago
RE: I am still not getting any
One would have to assume that you don't have the correct settings on the iPad, there really isn't any way for any of us to tell though.
gel
gel's picture
I haven't changed any settings, and I have tried a different iPad too and it's not working on there too!  Cleared cookies, done resets, still nowhere!
Stop
philipjohnwright's picture
Last seen: 2 months 3 weeks ago
Leave it a while and it will
Leave it a while and it will probably work. Then stop working again, then start again. I have the same issue, often supposedly down to using the wrong password. But then miraculously it works again using the same password (that is entered automatically).
If you have the same problem as me it's down to Bt, not the ipad. Having spoken to someone at bt at length the only think they could suggest was resetting the password across all my devices. That worked for a while but then the problems came back. I think it's BT's security software getting concerned about the account being accessed from multiple devices and assuming some of them are dodgy, so blocking them for a while. The BT guy alluded to this sort of, but couldn't suggest a permanent fix.
Bottom line is I'm having to live with it. Very frustrating, my only solution was to download their Mail App, which to be fair is good. But that means I sometimes have mail coming into two clients, which defeats the object somewhat.
gel
gel's picture
RE: Leave it a while and it will
philipjohnwright wrote:
Leave it a while and it will probably work. Then stop working again, then start again. I have the same issue, often supposedly down to using the wrong password. But then miraculously it works again using the same password (that is entered automatically). If you have the same problem as me it's down to Bt, not the ipad. Having spoken to someone at bt at length the only think they could suggest was resetting the password across all my devices. That worked for a while but then the problems came back. I think it's BT's security software getting concerned about the account being accessed from multiple devices and assuming some of them are dodgy, so blocking them for a while. The BT guy alluded to this sort of, but couldn't suggest a permanent fix. Bottom line is I'm having to live with it. Very frustrating, my only solution was to download their Mail App, which to be fair is good. But that means I sometimes have mail coming into two clients, which defeats the object somewhat.
Yep, that all makes sense - cheers!  Mine has been pretty much like that too.  But now I have really hit a brick wall - how annoying!  Thanks.
Stop
gel
gel's picture
RE: I just managed to get into it
I just managed to get into it again! How do I reset the clock again? Cheers.
Stop
gel
gel's picture
Dont worry, I just done it.  Smile
Stop
gel
gel's picture
It has gone again - OMG!
It has gone again - OMG! |(
Stop
gel
gel's picture
RE: iPad Problems
Stupid Apple!  Still not working, this is not good enough!   |(. What does one do?   :?
Stop
gel
gel's picture
RE: iPad Problems
Still not working!  Should I buy a Nexus 7?   :?
Stop
Pages
Log in to post comments
