4 posts / 0 new
Last post
psurquhart's picture
Charging question - iPad 4
Quick question about my new A grade bought from CEX iPad 4 64gb please. Very pleased with it considering I bought it with vouchers from selling things over the last couple of years.
Having not owned one before can I charge this using my iphone 5 lightening charger rather than the adaptor that comes in the box ? Probably a silly question but just trying to keep my charger count down.
Looking for a quick reply please ! Need to charge it.
RodhasGibson's picture
Last seen: 5 days 9 hours ago
RE: Charging question - iPad 4
Hi There,the answer is Yes you can although it will take longer.The best way is to use the iPad charger to charge both.That way you will get a quicker Charge on both devices. Smile
gel
gel's picture
Last seen: 7 hours 43 min ago
psurquhart wrote:
It does work, but I don't think it is as good though, but yep.
Stop
Ahhh, right. Will do this then instead.
Cheers to both reply's.
Log in to post comments
