4 posts / 0 new
Last post
thegravy's picture
Last seen: 3 years 3 months ago
CD Micro System with Lightning adaptor
Hi
I bought my mum a iPad mini last year and now want to get her a micro system so she can play all her cd's and itunes and listen to DAB radio.
anyone bought something similar, a lot seem to be for the old 30 pin adaptor, not the lightning, ideally don't want a cable for the lightning but rather a dock!
thanks in advance
John Duncan's picture
Last seen: 1 month 2 weeks ago
RE: CD Micro System with Lightning adaptor
Would Airplay not suffice? I always considered docks for iPads a bit...unsafe.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
BenLaw's picture
Last seen: 1 year 11 months ago
A few options are starting to appear now with lightning docks. The best option IMO is the panasonic PMX7DB. Onkyo I think also do one. However, I don't think either of these would fit anything larger than an iPhone. You could use an older model with a 30 pin dock and use an adapter. The standard adapter may give you stability problems. Last time I checked a better option would be the flybridge dock or the photofast lightning mount, although you may have to import these.
I am the danger.
thegravy's picture
Hi
thanks for the replies, I was looking at something like this
http://www.philips.co.uk/c/audio-system/dock-for-ipod-iphone-ipad-dab-plus-dcb2077_10/prd/
or something similar, just wondering if anyone had any experience with these
ta
Log in to post comments
