Better sound from iPad using camera kit and USB DAC?
17 replies [Last post]
bay24
bay24's picture
I have been reading that you can take the digital signal direct from the iPad using the USB conector from the camera kit. This means you can use a USB dac to improve sound quality (see link below).
http://www.benchmarkmedia.com/discuss/feedback/newsletter/2011/06/1/ipad...
Does anyone have experience of doing this? If so can you use any USB dac like the fiio e10 or 17? Seems like a very good way to get high quality sound on the move?
If this works I think it would be that one extra feature that would let me justify getting one!!
John Duncan
John Duncan's picture
Online
RE: Better sound from iPad using camera kit and USB DAC?
Sounds plausible.  No way I'm paying 25 quid to find out though...Smile
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
bigboss
bigboss's picture
http://www.amazon.co.uk/gp/product/B005KG7BB0/ref=pd_lpo_k2_dp_sr_1?pf_r...
__________________
John Duncan
Online
I'm not sure it's shiny enough...
__________________
bigboss
bigboss's picture
Oh it is shiny! Check the 2nd pic. It's not called "Shinntto" for nothing  Smile
__________________
John Duncan
Online
It's called something similar in some of the reviews...
__________________
bigboss
bigboss's picture
excellent!
__________________
Xanderzdad
Xanderzdad's picture
Ooh, I bought one of those 2 weeks ago. I'm off to try my speakers now. I'll report back.
__________________
Home Cinema - Sky HD, Panasonic DMP-BDT210, Denon AVR 2808 (Pre amp into MF A3.2 Amp), Monitor Audio Silver S8, MA RS Silver LCR, 4x Q Acoustics 1010 + sub, Mitsubishi HC7000 HD Projector
Stereo - PC/NAS (Synology DS212J), Squeezebox Touch via CAT6, MF A3.2 Amp, Monitor Audio Silver S8
Xanderzdad
Well my £5.59 Shinnto adaptor works perfectly with my USB speakers. I am very happy. Thanks for the tip.
Also works fine with my cameras SD card.
__________________
bay24
bay24's picture
Glad it's been of use! Still wondering if there are many portable DACs work in a similar way. There is a thread on headfi about it but it seems that often there s a need for an external power supply as the DACs drain too much power from the iPad and it is a bit inconsistent weather it works or not.
Fisherking 145
Fisherking 145's picture
bay 24 is right. I've just tried my E7, and the iPad says it uses too much power, so it can't be used on the move I'm afraid.
I have excellent results using the camera kit into my CDQ's USB DAC using lossless files, I actually think it sounds better than my Squeezebox Touch using coax.
__________________
Audiolab 8200CDQ Roksan Caspian M2 Power Amp Dali Ikon 6
Sony KDL46HX853 Humax Fox T2 HDR Sony BDP S570 Yamaha RX 3010
Other Stuff - HP Data Vault Squeezebox Touch Asus Xonar Essence AKG K271 JRiver Media Center
bay24
bay24's picture
Thanks for confirming! I am not sure it is that simple though as I believe that it may work depending on which iOS you are using. I would quite like to know if the rpac works, seems like it could fit the bill!
wilsmusic
wilsmusic's picture
Hi there,
Rpac does not work with my ipad2 sadly.  It might work in conjunction with a separate powered USB hub but I was looking for a portable option.
__________________
Arcam alpha 10, Arcam alpha 9P, Sony bdp s370, Marantz NA 7004, Quad 21L2 floorstanders, virgin TiVo, dell laptop and ipad as source for music, chord chameleon interconnects, fiio E11, Grado SR 80i, ATH-WS55i
wilsmusic
wilsmusic's picture
Hi there,
__________________
bay24
bay24's picture
wilsmusic wrote:
Hi there,
Thanks for the confirmation. That's a shame!
rjlawson
rjlawson's picture
The Fiio E7 works fine, but you have to set USB CHG = OFF in the menu first. And it sounds great to me!
