Root domain problem
The redirect from http://whathifi.com to the correct http://www.whathifi.com appears to be broken...
It's the first one that's the problem, but I have a non-cacheing browser: what happens if you do Ctrl-R (presuming you use FF)?
first link takes me to http://www.whathifi.com/ do a ctrl r and it stays the same. in FF.
Think it's been fixed...
now they have gone and changed the "active topics" to "latest posts" time to update those book marks....
Huh?
Huh?
if you wanted to see the latest posts over the whole forum you can use a button on the main page of the forum.
this used to be
http://community.whathifi.com/forums/TopicsActive.aspx
but this morning it no longer works. as it is now
http://www.whathifi.com/forum/latest-posts
Both the URLs you give work fine, and get you to the same page...
Nope, the root domain (http://whathifi.com) has stopped working for me again. Tell Gareth! Tell Gareth!
this used to be
...and has been since the site was migrated months ago...
the former as a (bookmark) worked fine uptill today. so something changed. as my bookmarks did not.
Yes, and I suspect there is something amiss with the old server, which has been redirecting to the new one since then, and appears to be failing to do so now (at least intermittently).
It's fixed. That'll be twenny guineas...
Both of your links take me to the WHF home page if that helps.
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
