Recomended setups incompatibility
4 replies [Last post]
rickskye
rickskye's picture
Reference nov 09 issue
Hi
At the start, page 6 to be exact, you tested Q Accoustics 2000 series speakers and paired them with a Sony STR DH800 AV receiver.
The output of the AV amp is 8 ohms and the speakers are 6 ohms.
Is this ok as I am lead to belive that if you use a speaker of lower impedance than the amp,  the amp will be overworked and possibly damaged?
I have a STR DN1000 av amp, which is similar to the Sony STR DH800, and the impedance is 8 to 16 ohms, so I would like to know the answer as I want to get the Q Accoustics speakers.
matthewpiano
matthewpiano's picture
Re: Recomended setups incompatibility
This will not cause you any problems at all.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
davejberry
davejberry's picture
I agree. The Sony amps (as most other av amps i know) will work quite happily with 4 ohm speakers. You just can't use two sets of fronts, for this they must all be over 8 ohms. It explains this in the manual.
__________________
LOUNGE: SONY KDL-46W4000; STR-DA2400ES & BDP-S350; SKY+; TOSH SD3010 DVD; PIO PD-F1009 MULTI CD; WII; KEF CRESTA 2 fronts,CRESTA 1 rears CRESTA CENTRE; BUDGET INTERCONNECTS & 79/42 STRAND OFC SPEAKER CABLES    BEDROOM: PANA TH42P-WD6;
rickskye
rickskye's picture
Thanks very much, both of you, for your replies.
I have read the manual from front to back but no mention of 2 sets of fronts, I suspect I can't do this anyway.
Rick
Andrew Everard
Andrew Everard's picture
No, you can't. But this is a case of a manufacturer playing it safe, given that speaker impedance isn't fixed, but varies with frequency. A speaker with a nominal impedance of, say, 8 ohms, may have savage dips in impedance at certain frequencies, and lower impedance sucks power out of an amplifier so fast that the power supplies can't top them up again fast enough (that's the very rough version!).
That causes distortion, which can damage speakers: most amps have cut-outs which shut down output to prevent this damage happening.
The variation in impedance differs from speaker design to speaker design, but trust us - you can use the speakers we suggest with that amp.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
