14 posts / 0 new
Last post
pioneer7's picture
Last seen: 3 years 1 week ago
pop up ads
Is it me...on certain threads or most there appears a high lighted word, can be any word [in blue] if you scroll over it, or click on it thinking it will take you to some thing conected to the thread an advert pops up either Tesco or Asda, in some cases it will take you to there sight, very annoying,can any one explain, or is it paid advertising from these stores.   :wall:
pioneer7's picture
RE: pop up ads
There you go see above thread Asda,and this one i suspect.
Andrew Everard's picture
Last seen: 3 years 3 months ago
RE: pop up ads
Think it may be something your browser is doing. There's no blue highlighting or linked advertising from this end...
relocated's picture
Last seen: 1 year 9 months ago
RE: pop up ads
I'm with Andrew on this.  Heaven knows I have highlighted the Stuff, blocking pop-up, annoyance a number of times without anything being done to sort it out but I have no experience of what you describe.
Apple lossless - Netgear Nighthawk - ATV3 - AVI ADM 40.
AVI ADM 9T used in my wife's system
chebby's picture
Last seen: 11 hours 55 min ago
RE: pop up ads
How about taking a screen snapshot when it happens and posting a link to it?
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
RE: pop up ads
pioneer7,
You may be running a browser extension or add-on designed to create automatic hyperlinks when it spots certain words: it's an advertising service, and one you should be able to disable simply by removing the extension, which may be described as a 'browser manager' or something similar.
Which browser are you using? Let me know and I'll have a look for extensions you may be running...
visionary's picture
Last seen: 2 months 3 weeks ago
RE: pop up ads
This happened to me about 2 moths ago and it was a "search"  program that had installed into my browser toolbar when I downloaded another program (memo to self always check everything it says on the screen)
The one I had was something.do - sorry I can't remember the "something" but it ended .do
Had to block the browser form using it and uninstall it from the toolbar.
Sorry it's a bit vague, my browser history doesn't go back beyond 1 month to confirm the name
bigboss's picture
Last seen: 1 week 20 hours ago
RE: pop up ads
Happens to me as well. Extremely annoying. On IE in Windows 8 phone. It's only happening since 3 weeks or so.
visionary's picture
RE: pop up ads
found it!
The one that affected me was snap.do and there was good advice on how to remove it on the web.
Symprtoms were as the OP described, random words became links to pop-up adverts
bigboss's picture
RE: pop up ads
Ok, I misunderstood the OP's post as I was in a hurry. My problem is different: there's an invisible layer of an advert all over the screen. When I try to click a thread, I'm taken to the advert, usually Currys. It's very annoying.
(Even more annoying than the fact that the angry smiley doesn't work!)
pioneer7's picture
RE: pop up ads
Thanks for the heads up
But you are asking the wrong question, my knowledge of computors is...well nowt but windows Xp if that helps
Can not think what I have done to have this happen, will ask my daughter later to confirm.
pioneer7's picture
RE: pop up ads
EErrm ok windows xp home edition and google chrome if this helps :oops:
RE: pop up ads
It's probably a sneaky bit of adware that's got into your computer somehow and is creating this text-to-link thing, called Text Enhance
To get rid of it:
Open Chrome, click on the customise and control icon (three bars or a picture of a spanner) top right of the Chrome screen, and go to Tools  then Extensions.
Select the Text Enhance plugin from the list of extensions, and click Uninstall or Disable.
pioneer7's picture
RE: pop up ads
Thanks Andrew will check it out Dirol
Log in to post comments
